So I removed my stock gutted airbox and jammed a Tenzo air filter on the end of the stock pipe. Seems like an inxpensive alternative to any short ram, plus it looks ok. Thoughts?
I don't mean to be a dick but as far as power gains you are not going to see any difference at all. You in fact may be loosing power over the stock drop in filter. I would probably run the stock air box with a drop in filter over that air filter. The filter you put on may sound better then your stock airbox but as far as power if it is a pod filter you are probably robbing power.So I removed my stock gutted airbox and jammed a Tenzo air filter on the end of the stock pipe. Seems like an inxpensive alternative to any short ram, plus it looks ok. Thoughts?
