1 - 17 of 17 Posts
Quoted from the addy u gave: The recall affects 2005 Honda Accord coupes, sedans and hybrids, 2005 Odyssey minivans and 2006 Ridgeline trucks, Honda spokesman Chris Martin told United Press International. It also affects 2005 Acura RL, TL and TSX sedans.
No RSX in the list :weeeeeeeeee:
:rotfl:
what was the reason for recalls?
I only heard that it is something that "might make the cars stop running and/or not start".
but if you followed one of the links, you'd actually know more of the root cause
2005-2006 model year vehicles from its Honda and Acura families may suffer from engine problems thanks to a potential fuel pump relay issue.
The recall is part of a larger global initiative that stems from errant sealer that might’ve come into contact with a coil wire inside said relay. The substance can apparently cause the wire to dry out and snap, which lead to starting and stalling problems.
1 - 17 of 17 Posts
