just out of the blue. its crazy.have you don't any rewiring lately? Tucking etc? Or did it just out of the blue magically happen one day?
i was reading that it could have found ground with the headlights. ,i do not btw have thoes manuals.Do your headlights flash when this happens?
I think shoegazer is on to something ... Something has gone wrong with the alarm or its relays and it is finding ground through the headlight circuit--which it would normally flash when engaged. Perhaps the relay that flashes the lights is stuck?
Do you have the Helms manual? There is a thread in the DIY section with a link to a PDF of it. That will show you where everything is.
ok i will after i get out of work, is this where the wires are located?yeah they are definitely in the same alarm circuit as the headlights flash as horn goes off when doing an alarm. Check all the wiring, ground, fuses, etc.
See this thread to download a copy of the service manual:i was reading that it could have found ground with the headlights. ,i do not btw have thoes manuals.
