1 - 8 of 8 Posts
Type-S Newbie
Did some search, but the last posting was dated '06... so I thought I'll ask and see what are some latest feedback about the Comptech Supercharger (CTSC).
How good (or bad) does the locked Stage2 map runs ? With proper install & components (i/h/e) , is the map good enough to left alone? This map should be a better one than the default 5-7psi JRSC map comes with K-Manager right?
Seems like nobody here likes a locked map in their k-pro... is it mainly because they like the tunability? Or is it really because locked map (reflash) are no good at all?
Tensioners... have both JRSC & CTSC improved their tensioners? Does Comptech still has a slightly better tensioner?
Type-S Newbie
every car is different, tuned > reflashed.
But the reflash from Comptech is not a "bad" map right? It can run the car fine, track the car alright, not gonna be bad on the engine etc?
Like the Honda #4, it's not a 'bad' map, one can keep this map and track their cars, etc. But of course with k-pro, there's a lot more power to be made.
Can the locked comptech map consider the same?
Where I'm getting at is, if I got the stage 2 Comptech SC kit along with their reflash, and not immediately get it tuned, it's not a BAD thing to keep using their map right?
Blown
Just do it right, and get all the necessary stuff to go along with your kit and you will see more power / reliability.
I ran it for a little bit.
Its def conservative.
I think the ignition is tuned for 91 octane.
And its def running on the rich side under normal circumstances.
When i went tuned and k pro it was night and day for power increase.
The rev limit is also premature and top end power is not really there compared to a tuned map.
Should be safe but there is always that risk.
1 - 8 of 8 Posts
