1 - 6 of 6 Posts
I installed the jrsc with my v2 but have not put the header on as of yet. My exhaust is stock. I hooked up a boost gauge and I dont seem to ever really see 5-5.5 lbs of boost. is this normal. I thought the 4.0" pully would peak at 5.5lbs? am just on crack or is something wrong? :driving:
What psi do you see on the gauge at redline then? What's your idle vacuum according to the gauge? Boost will increase as RPM increase with wide open throttle. You are not boosting 5psi even with wide open throttle at a low rpm. Check for leaks? Do you have abnormal idle? Tighten the belt?
1 - 6 of 6 Posts
