1 - 17 of 17 Posts
Its Always Sunny...
Ive tried to wire it up but it wont work. I tapped the red wire on the outer most bulb and grounded the negative, no luck.
Any tips? do I need to ground my negative to the bulb negative in order to complete the circuit?
First make sure you have power. Taps don't always make contact. Any metal should be a ground but you could test from your ground to your tapped wire to make sure. I know it sounds stupid but make sure your lights are on when you test the wires.
are u tapping it to be a rear fog light or when u hit the brakes?
check fuses, they always pop when u try to splice into live existing wires w/o disconnecting the battery
1 - 17 of 17 Posts
