1 - 2 of 2 Posts
my boost is hitting 8 to 9 psi and need to lower boost manually.one end of the rod as clips and bolt to hold the rod and one end goes to the actuator. which end do i need to turn out? i was thinking of just taking the actuator {2 bolts holding it} out and just turn it . would this work? instead of taking the clips out of the end.
Take the whole actuator rod assembly out.....it clips into a swing valve on one end and is bolted down with two bolts on the other end...when you get it out, use vice grips to grip the flat metal side and turn it to your left to loosen the nut......
1 - 2 of 2 Posts
