Hello!
First of all, please excuse my english. I am from Germany.
My problem is the following:
Today I bought a used RSX Type S (manufactured 2003).
First I opened and started the car by actually putting the key into the lock and into the ignition and everything worked fine. Later today, I tried to open the car with the remote control. (the two buttons on the key)
The remote control seems to have triggered the alarm system. The following is happening.
1) The security light bulb on the dashboard is flashing red. The manual denotes the light bulb with "5" as far as I remember.
2) If you open or close the door the lights of the cars turn off and off rapidly. They stop to do so after 1-2 mintues but the red light on the dashboard is still flashing.
3) If you put the key into the ignition the lights are flashing AND the car makes a lot of noise.
If you use the key instead of the remote it still opens and closes the door and starts the engine. But unfortunately it still triggers the alarm system.
Do you have any idea how to disable the alarm?
