1 - 1 of 1 Posts
West dc5!
This is the 2nd part of the video How to replace the throw-out bearing, clutch, and flywheel". There is a lot of good info in this one. You will see torque specs, steps of how to install the throw-out bearing, clutch, flywheel, where to add high temp grease. In addition of, parts and tools numbers and where to get them.
Since I removed the whole engine to fix an oil leakage, I was able to also shows what do you need to do to use an Acura RSX Type S oil pump in a K24 engine block to prevent oil cavitation on high RPMs.
Anyway, is there's a video you can't miss is this one. Like ALWAYS... Don't hesitate to contact me if needed. Thank you for watching!
1 - 1 of 1 Posts
