1 - 20 of 21 Posts
Are there any markings or distinctive traits that would help me determine the legitimacy of the camshafts that I just ordered?
Old member
i dont think u can tell....the difference is too small to tell by looking and supposeldy there are no markings or anything.
you can't.
if they came in boxes with honda part #s on them you can search on here for that part #. The correct part # for both cams is on this forum. If you can't find it I have the correct part # on my boxes and can post them if you need them. Only other way to tell differences is to measure duration which is next to near impossible.
I think that they have different numbers stamped on them. Do a search, I think edo addressed this a while ago.
the numbers that are stamped on them turned out to mean nothing.
try and make sure you get them in unopened honda boxes.
swwifty said:
they look exactly the same as the type-s cams.
The 2 cams will look the same, but I bet the lobes on the R will be....
more aggressive.
edit:
Sorry. Didn't see your post about measuring duration. :p
more aggressive.
edit:
trust me I've compared them in real life, absolutely identical
Yeah, looking at the lobes with the human eye, you are not going to see the difference.
Old member
Yup, the casting numbers arent consistent. I talked to edo about this aloooong time ago when I was gonna go with this setup but didnt wanna get ripped off.
Discussion Starter · #13 ·
thanks for the replies, I didn't think that they would look any different, but I had hoped they would have some sort of engraving. I'll let you guys know the details once they arrive.
Jurassic Member
Type R Cams
The Type R cams have two ridges on them at the end of the cam where the sensor rings attach I believe. Casting numbers don't mean much. The stock Type S cams don't have the ridges and are flat on the end.
Easy... :thumbsup:
if the type r and type s cams are the same, then how do the type r cams produce more hp? makes no sense.
Newbie
Easy... :thumbsup:
This guy is correct! :thumbsup:
You Like My Member
i believe the duration of the lift of the ITR cams are longer. though the lift is same. Correct?
if it is just a slight difference why buy the type r cams? sounds like a waste of money, or do they creat around 20 whp? or not even that.
1 - 20 of 21 Posts
