1 - 12 of 12 Posts
help me sort it out please
supertech valves ,
springs,
retainers,
guides,
3 angle valve job
ported and polished head
darton sleeves
arp head studs,
main studs,
rod bolts,
je jd pistons 9:1, hd wrist pins, 87mm
manley turbo tuff rods,
king race bearings supposed to be balanced to 10k rpm
TRANS ep3 5speed with wave trac lsd carbon syncros,
suspension
jdm suspension, cryo treated rotors ebc pads aspec wheels with bfg drag radials on all 4 corners, custom swap bar oem 5speed withstage 4 clutch. aftermarket axles stage 1
Discussion Starter · #2 ·
wow no suggestions???
Do I stink or something LOL who do I have to pay to get help around here? :p I would be willing to pay someone willing to travel here and help me out with their knowledge. I have bought 5 cars (4 TYPE S and 1 base) in 30 days and have alot of extras if you are wanting parts.I just am always going and do not have the time to read up and want to open this motor up before t is ran and make sure all is well in there.
Shazaam
What is your question? You didn't ask anything, you just listed mods to some mysterious engine that you bought.
Don't expect anyone to do leg work for you, anyone who knows anything put in the time to slow down and read up and they will expect you to do the same for yourself. Spoon feeding is for infants.
sounds like a bunch of assholes around here
Like he said, what is your question?
supertech valves ,
springs,
retainers,
guides,
3 angle valve job
darton sleeves
arp head studs,
main studs,
rod bolts,
suspension
No question about it, the answer is yes. You bought an engine with parts in it.
Vaginal Lubrication Tech
supertech valves ,
springs,
retainers,
guides,
3 angle valve job
darton sleeves
arp head studs,
main studs,
rod bolts,
suspension
HOLY SHIT! Thats the same setup Hank has on his ride
Did the engine come with a set of these installed?
VTEC?
This is how the HAMstar would have paid for the engine
Been Around for a while
So Bob...we are not mind readers and that does not make us assholes btw.
What is the question? Glad to help.
T
Shazaam
Sounds like a whiny, entitled prick in here
1 - 12 of 12 Posts
