1 - 13 of 13 Posts
my friend has an hid kit from his 01 maxima that he can hook me up wit... his car got wrecked but the ins co. paid for new everything so his old ones still work...is there n e way for me to hook it up for our car... n e help would be appreciated....thanx in advance!!! :thumbsup:
...gOt boOst
need to dremal the socket of the housing bigger for the bulbs to fit,and also the base of the bulbs.
more info please!!!
thanx RSX4U2NV
...gOt boOst
Okay....first u would need to make the hole in the housing bigger for the D2R bulbs to fit. Also u would need to modify the bulb base too. I'll post a pic of the bulb that I did up and u can follow there on....
...gOt boOst
You need to cut the base of the bulb to that same shape for it to fit.Btw use a dremal, it helps.
so i take it u've done this b4...what about the ballasts...is the connection going to be the same or will i have to modify those also...do u have a step by step instruction by n e chance?
...gOt boOst
No if u look at the bulb , its like a hat shape, just trim both of the top edges off. No need to do anything to the ballast. Btw no step by step. 1) make the hole on the headlight bigger and 2) trime both of the sides of the bulbs.
yawn..
sounds like a hell of alot of work
rsx2k2, you need to visit the local forum and meet up. Your show car is crazy
...gOt boOst
Sure, we all should meet up one day. BTw its not that hard. A dremal is all u need!
Long Member
Sounds like more work than it's worth....
...gOt boOst
Next time when I take out my headlights again. I'll take some pics of it to show u that its worth it.
1 - 13 of 13 Posts
