1 - 1 of 1 Posts
· Registered
i have a k24a4 block and crank i plan on using tsxk24a2 rods and pistons in.
the question in not properly answered.so i printed both a 2006 honda accord(k24a4) and 2006 tsx (K24a2) rod bearing charts off of ALLDATA at work today. as you can see the charts are different.
*BOTH oem bearings from each engine have identical Part Numbers in reference to each color.
the question.....WHAT COLOR CHART DO I SIZE MY BEARINGS FROM????
TSX OR ACCORD?????????????if i had to guess i would match the codes form my block with the tsx rods and use the tsx chart for size/color and gauge the bearing from there
tsx chart left - accord right
image hosting 30 mb
i have to buy bearings to measure clearance,bearings cost money,so i need to order bearings wisely to have as much of a accurate fit as possible and hopefully be right the first time.
1 - 1 of 1 Posts
