Go test your clutch
Highway, 6th gear, 35-40mph, floor it
rpms raise quicker than mph? if so, its your clutch.
no, it accelrates like a fucking champ bro.Go test your clutch
okay, how about 20mph in 6th? lolno, it accelrates like a fucking champ bro.
then your clutch should be fineno yesterday i floored it to 100 @ 6th on an open freeway just to make sure, np at all.
good question, checking right now.then your clutch should be fine
hows the fluid level?
:laughing: :laughing: :laughing: I love you, too?magnesium, i dont even fucking know you but thank you! my clutch fluid is depleted lol.
off to get it change tomorrow.
:weeeeeeeeee:
Low fluid usually indicates either worn cylinder seals or a leaking hose.magnesium, i dont even fucking know you but thank you! my clutch fluid is depleted lol.
:weeeeeeeeee:
I'm quite a noob when it comes to transmissions and clutches, please excuse this question.Using the 6th gear resistance check will help diagnose a slipping clutch. It won't do anything for a clutch that won't allow the gears to shift. Unless there is a hydraulic problem at the master or slave cylinder, the problem will usually lie in a worn pressure plate spring that just won't allow enough separation between the disc and the plate no matter how hard you press the pedal.
from what it said here, helps me alot. i think this is my problem. its hard to get it into gears and grinds alot. the pedal is really stiff too. i have a exedy stage 1. i think i am going to go with the CC stage 4 with their flywheelUsing the 6th gear resistance check will help diagnose a slipping clutch. It won't do anything for a clutch that won't allow the gears to shift. Unless there is a hydraulic problem at the master or slave cylinder, the problem will usually lie in a worn pressure plate spring that just won't allow enough separation between the disc and the plate no matter how hard you press the pedal.
where u been . so whats the problem your having????I'm quite a noob when it comes to transmissions and clutches, please excuse this question.
My car (03 type s) fails the resistance check in 4th, 5th, and 6th at around 20-40 mph. I understand this is a clutch problem, but what exactly is the problem besides slipping? Whats making it slip, and what, if anything, needs to be replaced?
It slips either becaues there isn't enough force clamping it down or the friction material isn't doing its job.My car (03 type s) fails the resistance check in 4th, 5th, and 6th at around 20-40 mph. I understand this is a clutch problem, but what exactly is the problem besides slipping? Whats making it slip, and what, if anything, needs to be replaced?
Hey man! How ya been? How's the car?where u been . so whats the problem your having????
Thank's for this info. I actually hear something that sounds like it could be a bearing rattling around at times, as I engage or shortly after engaging the clutch in lower gears. This noise only happens on occasion though, not everytime I engage the clutch.It slips either becaues there isn't enough force clamping it down or the friction material isn't doing its job.
Could be a number of things that caused it:
* Oil or grease contamination
* Incorrect release system adjustment
* Defective cable adjuster
* A blocked clutch master cylinder port or binding slave cylinder;
* A misaligned or improperly installed release bearing
* Worn out friction material
This is just my book knowledge though... someone with more experience might help narrow it down.
