you idle in col 2-3, between -17 and -20 in/hg
black soot is normal, i put black spots on my garge door/wall every morning.
just condensation that spits out with carbon out the tail pipe.
check the idle AFR, with stock injectors it should be near 14.5
another ntoe.... if u have ur car on, kpro on, u can see exactly which cells it is using for idle.. prolly row 3-4, col 2-3... cols 1-2 are reserved for decel.. that is when u see the most vacuum
