not getting any spark on ignition coils 12v when it’s on ignition go to crank it no spark, & the lowest it sees is 11v. I do have a ry wire harness
Took out the spark plugs & tried it outside of the car & no spark at all, spark plugs are as new as when I put them in.
i borrowed a friends stock harness rsx type s & ignition plugs don’t have no power it was grounded out, to valve cover
Grounds
Trans to frame
timing side cover to Frame
I have fuel pressure so I’m good on that side
I relocated battery to the trunk as well but I made sure it was done right with 0 gauge wire
& there is no codes of bad crank sensor or any other codes at all
Grounds
Trans to frame
