1 - 10 of 10 Posts
Just installed DW1300 injectors. My fuel rail is leaking fuel on the #3 injector from the left. Swapped injectors around and it's still leaking from #3 from the rail.
I applied the supplied "super lube" as instructed on all O-rings
Does the leak follow the injector or stay on that part of the rail?
Very likely the o-ring may need replacing. Does the o-ring look worn or damaged in any way (not perfectly circular like you'd expect)?
Have you used this fuel rail in the past without issue?
The injectors.are brand new. I had stock and id725 in the stock rail previously with no issues at all. It's leaking from the fuel rail, not injector actually.
2
Guest
I'd replace the O-ring. Highly unlikely the stock fuel rail is the issue.
Discussion Starter #6
swapped it with the orings off my ID's and fuel just sprayed everywhere. not sure which on sprayed out
2
Guest
You need to try some fresh, OEM Honda O-rings and lubricate them liberally with motor oil.
Discussion Starter #8
finally stopped leaking...idk what it was exactly but i pulled the rail back off, lubed both sides of all the orings liberally, got the stock retainer clips to fit, and put 2 thick washers on.
thanks guys!
I know this is an old post but im having slightly the same problem! also on the 3rd one as you mentioned. Instead of leaking from the fuel rail itself, i have some fuel coming from the connection between the injector and the intake manifold. its not spraying out a lot but its a fair amount. when the car key is on ignition mode, the injector makes a hissing noise and you see it starting to form bubbles as the fuel leak out onto the manifold. PLEASE HELP
Past Driver’s Ed
Check your injectors o-ring seals for damage. It doesn't take much damage to generate fuel leaks. I would just replace them.
1 - 10 of 10 Posts
