1 - 20 of 26 Posts
Big Pimpin
*Update*
I just called innovative and they said they'll pop out the urethane and replace with a new bushing for free, I'm gonna head over there since they're near me and get that done.
This is on a DCRH setup, but it may not be limited to just DC.
Just a warning to those running innovative mounts with no heatshield or anything.
I don't know if this is happening to anyone else, but I had to fab up an aluminum heatshield between the header and my mount because of...
So ya, just be on the look out.
G
I looked at mine and everything appears fine. How hot are your pipes getting, I wonder? You running super-rich, or something?
Ewhhh....that doesn't look good. The 60A bushings are supposed to be some tough polyurethane material. Your RH must be getting really hot to melt it like that....:noes:
I need to look at mines tonight.
-J
Retired OG
wow, maybe cause of your custom header? anyways good luck to gettin a heatshield up
F1 Crew #3
damn im off to check mine now. . . is it possible that your higher c/r and cams ect. could cause your egt to be higher? maybe not my knowledge on this is limited in any case thanks for the info
Big Pimpin
Discussion Starter · #10 ·
it's entirely possible. I know I'm not running rich, my AF is right in the mid 14's off the tailpipe sniffer. But ya, I wouldn't be able to tell you if it's cuz of the mods or not because I didn't get the innovatives put in until after I had all the motor work done. When I do get my custom hytech header I'll be coating and heatwrapping it.
As for the heat shield, what we did is took two small sheets of aluminum, drilled a hole and a notch (the notch is so they would fit around the subframe bar) and then we took the tranny mount bolt out and put it through the aluminum pieces and bolted it back in, that way the aluminum is right between the header piping and the mount.
I'll try to get a picture of it today.
Anything fast and brutal
The ceramic on the DCrh is ceramic in name only. It is not a true Thermal Barrier coating, it still allows alot of heat to escape the header.
That "homemade" heat shield should do the trick, a true gearhead doing what needs to be done!
Retired OG
it's a DCRH. Ceramic.
oh yeah i forgot :eek: I knew you were going to get a better header, just didnt know when
btw nice fab job :)
Big Pimpin
Discussion Starter · #14 ·
oh I know the ceramic isn't really protecting it, I just pointed out that it wasn't the SS header, just for an fyi.
And yup, it certainly has worked, the mount hasn't melted any more. Just aggravates me that it happened and I found out about it like a few weeks after installing the brand new mounts.
Great job on the heatshield
Also, correct me if im worng, but aren't the innovative mounts covered by a full warranty? and wouldnt this be means for replacment?
Retired OG
no why would it?
Innovative Mounts has engineered a unique polyurethane bushing unlike no other. Our bushings are solid, will never wear or break, and come with a life time unconditional warranty
Strait from the parts store, i would at least try to get a new set
Retired OG
somebody always trying to get something new for free....:shakehead
the warranty means for manufactuer defects not, personal errors.
1 - 20 of 26 Posts
