1 - 6 of 6 Posts
Orange=teh Sex
Hey fellow members,
I have had this issue for some time now but didnt have time until yesterday to fix it..or try to fix it..anyways i replaced all the bulbs that are suppose to light up the temp, and all the other options...also the little light by the cup holder is out also...all the fuses are fine..am i missing something?
cliff notes:
ac instrument cluster doesnt work
changed all bulbs
all fuses are fine
still nothing works
likes to troubleshoot
All those lights are controlled by the dash light brightness controller. Check to see that it's not tuned down all the way. The fuse for that circuit is under-hood fuse 2 (not under-dash). If that fuse is OK then likely the MOSFET inside the gauge assy. is bad, or you've got some hacked wiring somewhere (or both).
Orange=teh Sex
dimmer switch works fine, the following lights do not work,
cup holder
the cruise control light ( not the green one once its on cruise control)
fog light switch
the ac control does not work
instrument cluster works
1 - 6 of 6 Posts
