1 - 2 of 2 Posts
Hey guys and gals, new to the forums but not automobiles I have a problem with my 2004 rsx-s instrument cluster. I went to crank it one day and no gauges worked neither did the cluster lights also the hvac lights. My band aid fix I disconnect battery and have to keep doors shut then connect it and it works until I cutt the car off again. When I'm driving with it working the brake light will glitch like a bad connection. I replaced the ebrake switch, third brake light, checked all of the fuses, did cluster reset. I've checked simple grounds. I'm lost no engine lights. I made sure all fuses fit well. Has anyone had this problem. I've done everything I can think of hope I can find some help.
Thanks in advance.
1 - 2 of 2 Posts
