If its a type-s just drain it. fill it until it comes out the fill hole slightly. I believe i used close to 2 quarts on mine.
Np man. I purchased three to be safe and only used 2 :laughat:Sweet, that's what I planned on doing. Thanks man :thumbsup: I'm gonna order it now.
Do you think amsoil is worth it, in your opinion? I'm ordering it either way, just curious.
GL man. :thumbsup:Lol oh well. A little extra never hurt.
hahhaha oh the Yaris...I don't know why you are comparing manual to automatic, two completely different transmissions and different fluids. that's like comparing a mustang to a yaris
first time over haul will use a little bit over 2 quarts for meI'm gonna buy some Amsoil Syncromesh for my Type S, but I just wanna make sure that 2 quarts is enough. It says in my owners manual that it holds 1.6 quarts for manual, but for automatic it holds 2.9. That's a big difference.
Just wanna see if 2 quarts is really enough. All I plan on doing is drain the old, put in the new.
2 quarts will cover it if the entire trans has been flushed from the rebuild. You'll use the majority of the two containers, but don't necessarily need to use it all. I think Acura calls for 1.9 quarts.how many quarts do i need if i'm having my tranny rebuilt? any help
Correct. You'll use just a bit over 1.5 quarts. If you fill it to where it comes out the fill hole, you technically overfilled it, though it's not going to hurt anything physically, it will increase fluid drag a bit.Koolass said:It shouldn't even hold 2 quarts, right? Since I'm just doing the drain/fill method, not flushing it out, I think it holds like 1.6 quarts then.
