1 - 11 of 11 Posts
DC5spd
I'll be purchasing an HKS hi power cat back exhaust soon and I also love the ITR rear lip to death. Is there any way to fabricate the lip so it wouldn't get burnt? :( Im not sure if this was been covered before, I tried searching but no luck.
Anybody has this set up? Pls, any good info will appreciated
thanks,
ric
I've seen a couple old threads where the owner just modified the exhaust brackets so it didn't angle at the end. This solved the burnt lip problem. If you really want to keep the exhaust angled then some people have gone to body shops and had small metal plates fabricated and put on the underside of the bumper just above the tailpipe.
DC5spd
i'll prolly go that route....metal plate above the muffler
thanks
any more opinions on this matter
Si vis pacem, para bellum
the muffler never gets hot enough to burn the lip of your bumper...that black crap you see on a lot of cars is just burnt oil or unburnt fuel.
DC5spd
and that can be easily wiped off?
thanks,
ric
anymore info would be appreciated
baby buffett
?? The HKS HiPower will melt the ITR lip without problem.
type-m?
i've asked this same question and the responses were that it may take a bit more than just fabricating a new bracket. if you go the hks website and view the dc5r+hipower video clip, you'll see that the muffler hangs a lot straighter on that car. in fact, it looks like a completely different setup in my eyes.
i thought about purchasing a jdm spec hipower, but eventually just gave up. when are you planning to do the install? make sure you post back here on whether you can get it to work or not, cause it seems like there are a number of other people in the same boat as we are.
btw, some people have commented that hipower is in fact melting/bubbling the paint on their usdm oem lip kits. a heat shield or a longer hanger that brings the tip further away from the lip will fix this.
DC5spd
Discussion Starter · #10 ·
At the Socal meet yesterday, The owner of the HKS promo car ( gold is the color ) has the HKS and ITR rear lip. He just told us that you need to extend the hangers so that the muffler would hang lower, not burning the lip.
So i guess the best way is to go to a muffler shop and have the hangers longer.
Hope that helps to the peepz who would do this particular set up
thanks again for all the replies
1 - 11 of 11 Posts
