1 - 11 of 11 Posts
· Registered
Anything special we should know or be aware of? Looking for somebody with some answers and experience in this area. As these cars become more and more rare, it's harder to meet mechanics who have been through it. I think I my Type S might be burning an unacceptable amount of oil now, and I need to prepare myself if that's the case. Thanks all..
· WILDCARD!
2006 RSX Type-S
I mean...these engines are still fairly common and well-supported in terms of maintenance items. A lot of Honda's from 2002ish through the early 2010's had K-series engines (RSX, Element, Accord, CR-V, Civic Si, etc.). Is there anything specifically that you're concerned about?
· Registered
Thanks for the reply. I had my oil changed in Nov. by Acura. I just checked the oil levels yesterday after a little over 1k miles of driving, and I'm already below the low level marker on the dipstick. Has me a bit concerned. Any thoughts?
· Super Moderator
Id
That's what I'm worried about. What are some of the potential causes of burning the oil up, and what are the fixes?
I’d think it’s making its way past the piston rings and into the combustion chamber. It’s normal for our cars to burn oil, but your situation does seem excessive. Any smoke or burnt smell from the exhaust?
· Registered
02 Rsx Base converted to manual k24a2
It's an inconvenience to try and keep up with burning oil, especially if you like to crack vtec here and there. I once let me car burn oil and didn't keep track of it as I should have. Long story short, I found myself next to a Prius in k20a2 swapped Ep3. He wanted some and I went for it, next think you know, my car started knocking. I oil starved it and damaged the rod bearings.
Start thinking about an engine rebuild. While you're in there it might be a good idea to knock out the head gasket, piston rings, valve seals, timing chain/tensioner, and maybe even the rod/crank bearings.
· Registered
Discussion Starter · #8 ·
Id
Nothing like that that I've noticed, but I'm probably going to need to pay closer attention because it may be there and I'm just missing it. After hearing about Honda's info stating that it's normal for the RSX to burn oil (1qt every 2,500k on average?) that gave me a little hope.
· Registered
JJutsu, I wouldn't sweat it. try and get into the habit of checking your oil every time you're pumping fuel. Keep running that engine and topping up oil until it won't run anymore. You could get another few hundred thousand miles out of it, who knows? On a side note, I would start putting a little money aside for a K20A so when the day does come you're ready lol.
1 - 11 of 11 Posts
