1 - 9 of 9 Posts
Hi, looking at buying a Jackson Racing Header that was on a RSX-S to fit my 2005 Honda EP3 Civic Type R K20a2 engine.
I was wondering if it would all fit and mate up to existing standard exhaust.
And also if anyone knew where I could purchase a high flow CAT.
Your thoughts would be greatly apprieciated!
Race headers eliminate the cat, so if you are looking to purchase a race header why are you also looking to purchase a cat?
Team Swift Stars
jrrh is 2 piece design, header and test pipe. so it's pretty easy to swap test pipe to a cat.
or if you have enough $$$, mugen race header(which has cat already) is great choice
No Longer Blown...
Jackson Racing is the brand.
It's not a race header....
The Jackson Racing header IS a Race Header. It's a two piece that eliminates the cat = Race Header
No Longer Blown...
And since you have a K20A2, the Header should bolt up with no problems, it will fit with the stock exhaust too. You will be getting rid of the existing header/downpipe/cat. Like kiwookster said, u can replace the test pipe portion the the RH with a high flow cat if u wanted to.
BTW, an EP3 with a K20A2 must be fun as hell to drive!
1 - 9 of 9 Posts
