1 - 4 of 4 Posts
did the wiring conversion correctly blew my share of fuses before I got it right. Not to soon after one light started to flicker then turn off, re-did the wiring and no flicker and no light...the wires have power they touched by mistake and killed another fuse....could it be the bulb or the actual hid unit?
is it only one side that is doing it ? tape up all bare wires then try swapping ballast and bulbs from side to side to elimiate the problem
it doesnt go ne faster!!!
buy my oem jdm hid unit which is plug and play, problem solved :D
DSM DC5
Are both of the lights doing this? I fried a ballast with water condensation, it flickered and shut off. I did the trial and error by using the ballast off the other side, headlight worked. If the ballast swap wouldnt have worked, I would have swaped bulbs, then ignitors etc....
I used a ballast off of a TL...The only difference is the JDM DC5 ballast has a ground mount. Buy a TL or TSX one and mount the ground wire to the screw which holds in the ballast.
1 - 4 of 4 Posts
