1 - 20 of 237 Posts
PM ME... your setup and we will add to the list.
Use the following
Supercharger type:
Crank Pulley TYPE:
Spacers used or Spacers not used
supercharger pulley size:
belt brand
belt size
Jackson Racing Charger
Setup with AC and Alternator spacers installed
Crank Pulley: K20z1
**SC Pulley: 3”
Goodyear Gatorback 4060805
**SC Pulley: 3.2
Goodyear Gatorback 4060812
**SC Pulley: 3.4
Goodyear Gatorback 4060815
Crank Pulley: K20A2
**SC Pulley: 3”
Goodyear Gatorback 4060810
Goodyear Gatorback 4070810 (7Rib)
Gates 4060806
**SC Pulley: 3.2
Dayco 5060805
**SC Pulley: 3.4
BELOW THIS LINE
Jackson Racing Setup WITHOUT AC and Alternator spacers
Crank Pulley: K20z1
**SC Pulley: 3”
Supercharger type:JRSC
Crank Pulley TYPE:Z1
Spacers not used
supercharger pulley size: 3.0"
belt brand: gator
belt size 4070810
**SC Pulley 3.2”
JRSC - 3.2" pulley
A2 - crank pulley
belt size: 4060812
without spacers
**SC Pulley 3.4”
Crank Pulley K20A2
**SC Pulley: 3”
**SC Pulley: 3.2"
**SC Pulley 3.4"
A2 crank pulley
3.4" blower pulley
NO A/C or alternator brackets
Goodyer Gatorback 4060827
Others setups
K24 Block
K24 cp
3.2" bp
no spacers
4060817
K24 Block
K24 cp
3.2" bp
no spacers
4060817
Dittorsx
3.2 pulley
jrsc
k24 crank pulley
good year 4060817
spacers used
this setup works perfect for me , and im hiting a peak of 13 psi and 11.5 to 12.5 psi contant
User: Kingnacho83
Supercharger type:EP3 JRSC
Crank Pulley TYPE: A3
Spacers not used: NO
supercharger pulley size: 3.8"
belt brand: Gatorback 4070662
belt size: 62.22" 7 Rib
PSI:7-8 ( 8psi [email protected])
User: TK-421
K24 Block
K24 cp
3" bp
no spacers
4060815
K24 Block
08-09 Accord K24 cp
3" bp
no spacers
4060817
k20z1
jmercado bracket
no spacers
3.0 blower pulley
k24 crank pulley
4060815 or
4080815 ( cut extra rib, its what i did)
User: himsweet66six
Not Fast Enough...
Supercharger type: JRSC
Crank Pulley TYPE: A2
supercharger pulley size: 3.2"
belt brand: Dayco 5060805
belt size: 80.5" 6 Rib
Not Fast Enough...
u fit the 80.5?
Yeah without a problem, and now that the belt is fully broken in there is still a lot of movement left for the tensioner :thumbsup:
I actually got the belt on by putting it on all the pulleys, even the p/s, first and then putting in on the tensioner pulley last. Since it (the tensioner pulley) doesn't have a rib you have to get over it just slipped right on without a hassle.
Alky fed rat.
Spacers not used
belt brand: Gatorback 4070810
belt size: 80.98" 7 Rib
Working perfectly
Alky fed rat.
**SC Pulley: 3”
I only found this in a 7rib there is no 6 rib for goodyear gatorback, iam still going to try the 7rib
7 Rib is the one you need. Part# 4070810
help me here ..
may be i am using the wrong belt .. i found the first gear and second gear sliping .
may be its the problem of belt , or the clutch , but the clutch is new ..
the belt i am using
jrsc
belt brand name : gates
K070786
pully size 3.2
with AC
k20a2
information of the belt
Effective Length (In.) 78.62
Effective Length (mm) 1997
Number of Ribs 7
Outside Circumference (In.) 79.183
Outside Circumference (mm) 2011
Top Width (In.) .947
Top Width (mm) 24
Alky fed rat.
help me here ..
the belt i am using
jrsc
K070786
pully size 3.2
with AC
k20a2
Number of Ribs 7
Top Width (mm) 24
This Thread is for te Jmercado bracket specically, doesn't sound like you have that. A datalog in Kpro is the best way to tell if its belt slip. If its your bclutch you will know if you get on the highway in 6th and accelerate, lots of revs and no mph.... clutch.
Discussion Starter #17
hey....what belt comes with the street kit and will that belt fit the 3.2" pulley with a2 cp on ur your bracket?
the belt it comes with does not fit. see if the are willing to price without the manual tensioner and belt.
Artic Blue RSX-S!
no..i already have that setup on my car rite now....and im thinkin about buying the bracket from you but since u said the belt will not fit....im gonna have to buy the belt too then
what do you guys think?? maybe the 82.2 ?????
Supercharger type:jrsc
Crank Pulley TYPE:k24
Spacers used or Spacers not used:no
supercharger pulley size:3,2
belt brand not sure
belt size notsure
1 - 20 of 237 Posts
