221 - 237 of 237 Posts
Can someone tell, what belt size will be needed:
Supercharger type: JRSC
Crank Pulley TYPE: Z1
Spacers not used
Supercharger pulley size: 3"
Alternator pulley: 4"
Thanks
Here's my setup: 2006 type S
Supercharger type: JRSC w/Jmercado bracket
Crank Pulley TYPE: K24a4 (5.96)
Spacers used or Spacers not used: No spacers used
Supercharger pulley size: 3.0
Belt brand: Gates
Belt#: K070810. 7 ribs for her pleasure
2006 type S
Supercharger type: CTSC
Belt brand: Gates
Belt#: K070810
The tensioner is at the loose edge of the middle rectangle.
K070805 was too small.
K070815 was too loose.
Hello guys, can someone tell, what belt size will be needed for:
Spacers not used
Supercharger pulley size: 3,4"
sCrEwEd.BoOsT.ShE.sCrEeMz
Crank Pulley TYPE: Ralco rsx type s CP, not sure size looks quite a bit bigger than k20aR CP
Spacers not used
Supercharger pulley size: 3.2"
Alternator pulley: JR supplied pulley
Belt: Gatorback 4070825 <<< belt to big arrow dont line up on auto tensioner. 4070812 or 4070815 should be ideal.
I have yet to start my car S/C but after some research no one uses 4070825 and only the other 2 listed above.
doesnt look like anyone is into this thread anymore lol anyways im updating my post above.
goodyear gatorback 8060815 is perfect belt for my above specs ^^^ :thumbsup:
Ctsc k24a2 with 3" bp , anyone know what size belt can I use on it?
k20z1
jmercado bracket no spacers
3.0 blower pulley
k24 crank pulley
4060815 or 4080815 ( cut extra rib, its what i did)
User: himsweet66six
If you wold of read thru all of the thread you would of found this.
This will only work for you if you have a jmercado bracket.
Not sure if the same belts wrk with ctsc? I would think they would though.
Always on TDY...
New setup:
Engine: K24A2
Crank Pulley TYPE: K24 CP
supercharger pulley size: 3.2" BP
belt brand: Gatorback
belt size: 4070810
J merc auto tensioner
02 RSX type s
K20a2 crank pulley
Supercharger 3.0
No spacers
Can anybody tell me what size of belt I need or if I need any spacers and where to get them
02 RSX type s
K20a2 crank pulley
Supercharger 3.0
No spacers
Try 4060812. That will wrk perfect.
J merc tensioner
Thanks JDMster82 I will try it if any body else have a difrent opinion please let us know
02 RSX
K20A2 crank pulley
Supercharger pulley 3.0
No spacers
JR supercharger
Ya on top of both posts he made it says j mecado tensioner
Hey guys I know this thread has been dead for two years but I need a little help.
K20a2 bottom
Oem p/s pulley
No spacers
3" blower pulley
K24 crank pulley
JRSC
Does anyone know what size belt I need? I kept my oem ps pulley on because I could not find a replacement Jackson racing one, they aren't in production anymore. Any insight is appreciated
k20z1
3.0 blower pulley
k24 crank pulley
User: himsweet66six
Just wanted to update everyone. I have this exact same set up and used the 4080815 and it worked great for me as well. I def recommend trying to loosen the belt up a slight bit before installing however you can though. It was very very tight going on, but once it breaks in it's going the be perfect fit
Senior Member
Just doing a little homework before I tackle another install. Specifically, the belt and belt size I will need. Notes I made, after reading the entire thread and searching on the net.
First thing to note:
Products previously branded Goodyear Gatorback are now under the brand name Elite following Continental's acquisition of Veyance Technologies.
Next:
There are quite a bit of discrepancies on belt sizes to use, probably due to so much complication and confusion on what is what. The thread starter (jmercado) should really clean it up and have it perfected by now for people/customers.
It should really have it concise and abbreviated for simplicity:
bp (blower pulley) size
cp (crank pulley) size
engine displacement (2.0/2.4)
PS pulley: OEM or JR supplied
JR supplied spacers, or no JR supplied spacers for the Alternator and AC compressor
AND FINALLY, JR thread and CT thread
Next:
The JR supplied spacers are useless with the jmercado bracket, but many still have them in and find it extra work to have to remove them. Yet, leaving them in leaves a point of failure for the supercharger system once you decide you need to add so much tension to the belt/system. AKA: junk, don't use them unless you have the manual tensioner from JR
And Finally:
These are the actual belts available to use:
partfinderelite.com search gives
4060805
4060809
4060812
4060815
4060817
4060820
4060822
4060824
4060827
4060832
4070805
4070810
4070825
4070830
CLIFFNOTES: GATORBACK IS NOW CONTINENTAL ELITE, there is some confusion as to what belt to use, and the belts available on the market are above.
