Long story short it is cut in 2. Somehow it welded itself onto the blower and I couldn't get it off. Because I was having so many problems with it, I wanted to go back to the 3.4" for better realibility.Steve Lloyd said:
Long story short it is cut in 2. Somehow it welded itself onto the blower and I couldn't get it off. Because I was having so many problems with it, I wanted to go back to the 3.4" for better realibility.Steve Lloyd said:did you sell the 3" pulley with your kit?? I'm stil lwaiting for JR to get me one, but htey are dragging their feet. With this new belt problem, I may never see it. I'm on the 3.4" pulley with the original belt and no issues, so I would like to get a hold of the 3" pulley.
I had that same problem with the 4". It wouldn't come off the shank for the life of me. I had to tap it off forcefully, which actually pulled the shank out a little bit...K20A2 said:Long story short it is cut in 2. Somehow it welded itself onto the blower and I couldn't get it off. Because I was having so many problems with it, I wanted to go back to the 3.4" for better realibility.
Texas-R said:I loaned this guy my stock JR pulley as a model and he did up a 3.2" and a 3" for me. Quality is better than stock (nice black anodize finish and +-.005" on dimn.) :thumbsup:
http://www.pulleyboys.com
Click on "Acura RSX-Integra".
haha, me too, if it is I can tell you how to cut it off.jsfwds2k said:I hope mine isnt' this hard to remove!
jsfwds2k said:My P/S pulley and blower pulley all have the shelf you are talking about. I am still assuming that my crank pulley is messing my setup up. The reason why I think so is: when I drove my car with the blower on it for the first time I drove it to the shop to put on the crank pulley. It made it all the way to the shop boosting a little bit. Now I can't make it down the street from my house with a 7 rib belt. I have gone for weeks on my 6 rib belt though. I think the pulley is too big and causing the belt to rub on the tubing coming out of the motor. Thus when I use a 6 rib belt and put it all the way to the passenger side I have no problems because the belt is not hitting that last rib on the tubing to throw the belt. If anyone else agrees with my theory please say so. I need to think I am right before I order a new blower pulley to make 9 PSI with the stock crank pulley. I also hope to get a new tensioner, and belt from Jackson. I know I did something with the crank pulley and that they shouldn't warranty this but I also think that this problem might be because of the tensioner. SO it is part their fault and mine. But I spent the 3700.00 to buy this kit and they should do a little something for me as well as anyone else having related problems. BY the way I have gone through 4 belts and haven't asked for a free one yet!
Jamie
Does the shank just go back in easily or what? How do you know if you got it in all the way? Man I hope I don't have this problem when I get my blower pulley..\\ad .\\ax said:I had that same problem with the 4". It wouldn't come off the shank for the life of me. I had to tap it off forcefully, which actually pulled the shank out a little bit...
I didn't notice the shank was pulled out a bit when I installed the 3.4" pulley. I did notice the pulley was misaligned, though. 2 weeks after installing the 3.4" pulley, my belt shredded. That's when I noticed that the shank was actually pulled out a little bit. I tapped it back in with a hammer until the pulleys lined up perfectly, everything's been running like a charm since.jsfwds2k said:Does the shank just go back in easily or what? How do you know if you got it in all the way? Man I hope I don't have this problem when I get my blower pulley.
Jamie
I hope thats how easy mine is. I am going to take off the orig 4" pulley, replace it with JR's new one, test that out for a few days so I can report back to Keith how its holding up then throw on my 7 psi pullytt061880 said:I think that only happens to a few of us, my 4' pulley came off by just using my hand to pull it out
:iamwiths:alphaSSmale said:Does anyone know the easiest way to remove the blower pulley? Do I need to buy a pulley puller?
i use a grip wrench found at autozone to hold on to the pulley, and then use a big torque wrench to loosen the bolt.alphaSSmale said:Does anyone know the easiest way to remove the blower pulley? Do I need to buy a pulley puller?
