I don't know how to start this but it was kinda funny how I finally got the Goodyear 77.5 belt fit onto car just like Mateo say and at the same time I found out how to fix the problem that guys with k24 crank pulley have. This whole time I ran the belt from the top of the crank pulley down under the waterpump then go up to the p/s pulley. This totally the wrong way to do it but by doing it this way, I was manage to fit a 79.6 belt but since this is the longer way, the 77.5 didn't fit at all. It's funny sometimes invention happens by accident so here it goes:
cure for k24 pulley hitting the rubber hose:
The problem: the k24 crank pulley(c/p) is bigger than our stock pulley, right obove our crank pulley there is a rubber hose so when we put the k24 c/p, the belt will hit the rubber hose and can cause damage to both hose & belt.
The cure: instead of run the belt from top of the crank pulley str8 to the idler and to the p/s pulley, you will run the belt from top of the c/p down under the waterpump pulley and then up to the p/s pulley. By doing it this way, you will never hit that rubber hose! You will need a longer belt to do this, I suggest something a bit longer than 79 inches long since the k24 c/p is bigger than ours stock.
Disclaimer: I mean no harm to this online community and I just wanna suggest ways to fix things. Althought running the belt from on top of the crank pulley down to the waterpump wasn't the way that JR suggest but I've been having it this way for over a months now with hitting the track on every wednesday so you guys can consider my car been a test car
. Please try this at your own risk.
