best way to tighten your belt on the JRSC
all -
i would just like to say that the method suggested in this thread for how to tighten the belt works great. ill review it now for those unfamiliar with it:
1) turn on car, turn on A/C on max, turn on all electronics, etc.
2) turn the steering wheel all the way to one side
3) if you hear a squeak or squeal from the belt in step 2, turn off the car and give the bolt on tensioner one full turn. go back to step 1 and repeat until there is no squeal.
if you think your belt is too tight, loosen it one turn at a time until your belt squeals doing the above procedure. then tighten it one more turn just enough for the belt not to squeal.
this method puts perfect tension on the belt, and makes it the least likely you will throw or shred your belt.
:-D
