1 - 20 of 59 Posts
Boost... My Anti-Stance
Background- car was purchased new back in June 2003 as my first car. She was my DD for over 8 years and never let me down- and minus a decade of road rash and acorn dents, she has aged pretty well. I have collected a few parts over the years so lets jump right into it.
Guts:
03 jdm dc5r k20a
-k20z3 upper chain guide
-HPT lower chain guard
-K24a2 crank pulley
-Custom valve cover
-Tractuff oil pan baffle
03 jdm dc5r 6 speed LSD trans
-CC stage 4 clutch kit
-CC ultra light flywheel
-Mspec race shift springs
-hybrid racing shift cables
-corsport steel braided clutch line
JacksonRacing RSX spec supercharger kit
-pulley boys 3in pulley
-Jmerc Racing stage 2 aftercooler
-Jmerc Racing high flow inlet
Stiegmierer supercharger porting
-ported blower housing
-venom cooler w/ rebuilt snout
-lightened rotors w/ recoated rotors
Vibrant 3.5in velocity stack
Hybrid Racing 74mm throttle body
Hybrid Racing rad hoses (EP3)
Hybrid Racing oil cooler hoses
Hybrid Racing fuel rail
Hondata 4 bar MAP sensor
DEI gold reflective tape
Ktuned spark plug cover
Ktuned oil cap
Ktuned dipstick
Ktuned drain plug
Ktuned TPS sensor
Ktuned idle air delete
Ktuned tensioner cover
PLM RSX spec race header
Custom Kteller straight pipe 3in Exhaust w/ Vibrant stealth muffler
Custom 3.5in cold air intake w/ AEM dry flow filter
Alcohol Injection Systems 3 gal trunk mounted meth kit
-18gph nozzle in intake tube
-steel braided line upgrade
AEM progressive meth controller ver2
Innovative 75a motor mounts (4)
Ingals Stiffy engine torque dampner
Buddyclub Spec Condensor
T1R IAT sensor
Mishimoto low temp fan switch
Mishimoto radiator
Mishimoto catch can
Mishimoto 12" slim fan
NGK 9s
ID1000cc injectors
AEM fuel pressure regulator
Aeromotive fuel filter
DW 265 in tank fuel pump- hardwired
Full - 6an steel braided supply and return fuel lines
Bolt boys (downstar) complete engine, trans, mount, and chassis SS hardware
Stiff stuff:
BC racing type BR coilovers
hard race roll center adjusters
energy suspension poly front LCA bushing kit
energy suspension poly front sway bushing kit (stock bar)
corsport adjustable metal sway bar endlinks (front/ rear)
energy suspension rear trailing/ hub poly bushing kit
Ingals camber bolts (front) adjustable camber arms (rear)
DV race adjustable tie rods
T1R inverted tie rod ends
Aspec front tower brace
DC5R front lower brace
Skunk2 rear lower control arms
Cusco 25mm rear sway bar
Megan racing rear tower brace
Megan racing C pillar bar
Progress rear lower tie bar/ brace
Stoppers/ rollers:
Wilwood dynalite 4 pot front BBK
-2 piece rotors
-race pads
-steel braided lines
-high performance brake fluid
PassWordJDM rear slotted/ drilled brake rotors
Hawk HPS rear pads
technafit rear steel braided brake lines
Buddyclub P1 racing SF challege wheels
-17x7
-+42
-5mm spacer in front (BBK clearance)
Bridgestone Potenza RE-11A 215/45/17 tires
Inside:
Hondata kpro ver4
Buddyclub P-1 racing bucket seats
Buddyclub racing seat rails
Buddyclub short shifter
UKDM CTR gauge cluster
LHD CTR floor mats
corsport shifter base bushings
ICB motorsports weighted shift knob
EBAY shift boot
sticker bombed dash/ door pillars
Autometer boost gauge
Corsport steering column gauge pod
AEM wideband
Semi gutted hatch
Custom mounted battery/ meth tank in hatch
Corsport Red steering wheel H
Outside:
Beater
-JDM front end w/ VIS racing Mugen rep front lip
Seasonal
-JDM front end w/ airwalker japan front lip and SSR carbon rad cooling duct w/ ARC ek4 winglets
HFP side skirts
DEPO JDM CTR rep black housing headlights
Seibon OEM carbon fiber hood
Aerocatch locking hood pins
PasswordJDM quick release bumper ties
HFP rear wing
Modified/ cut OEM rear bumper
JDM front and rear red H
Golden eagle rear tow hook
Might be some that i missed but thats most of it.
Car was tuned by Derek @ IMW in carlisle PA
Most recent: 354whp/ 238wtq @14psi on 93... 382whp/254wtq @14psi on e85
Thanks for looking
Sent from AutoGuide.com Free App
Best EP I've seen in a while. Clean work on the motor, No ghetto fabrications on this one. Super sexy, and pure inspiration!
Discussion Starter #5
Thanks for the kind words. Idk about inspiration- but I was going for the total package. Just a seriously fun car to drive and enjoy. Simple clean and functional
Super clean bro! I bet That's a very fun car to drive! I don't get tired of driving my car as it is now. If I had your setup I'd find every excuse to drive, lol.
"I stubbed my pinky toe babe, I'm going for a drive"
Discussion Starter #8
Yea that pretty much sums it up
Discussion Starter #10
nice numbers!! that's more than double the hp of what you get from a stock engine, very impressive
Thanks- the k20a does pretty well and is set up and tuned very conservatively for reliability and drive ability. My old k24a2 setup was a different story. Before the bearings in the blower seized prematurely, taking out the motor, it topped out at a record 416whp/305wtq @14psi on e85... It was a real hand full.
Discussion Starter #18
Some winter projects going on. New stuff:
TSX crank pulley
Kpro ver 4 upgrade
AEM ver 2 progressive meth controller (rewired for trunk mounting)
Custom 3.5in CAI
18gph meth nozzle upgrade
Rewiring the entire meth and aftercooler stuff has been a pain. Between the first controller and harness being bad to all the corroded grounds- it's been a handful. Everything is pretty much handled as of now. Waiting on a slightly smaller belt before retune. Pics:
Some of the new meth controller setup:
1 - 20 of 59 Posts
