So I put that spacer in and did the idle learning on the ECU and now my problem seemed to get worse. It will not idle below 1100 RPM now. There are two things I have noticed, first if I listen closely I can hear what sounds like a muffled popping noise coming out of the tailpipe. Can this be detonation or backfire? Also what I did was hook up my ODBII scanning tool and took a look at the O2 sensors. I graphed out the result, take a look and let me know what you think.
O2 Graph At sample 66 is where I reved the engine and that is the only point where the two sensors read the same. I dont know a lot about O2 sensors but I would think that because I am running the JR Test pipe the sensors would read the same. Maybe someone else with a scan tool can look at their sensors and see if this is normal.
Is it possible I have a stuck IAC valve or bad O2 sensor? I ordered some Denso IK24's from Clubplug.net thinking that one of my plugs could have gone bad but I dont know when those will come in. I am really at a lost at what to do next. Tomorrow I am going to stop by the gas station and pick up some butane so I can do a vacuum leak test.
One more thing, if I had bent valves could that be causing this???
~~EDIT~~
XTRMRSX said that he had the same problem when he left the stock orange gasket in where the IAC spacer goes. He mentioned that once he took that out and used just the paper gasket his idling problems went away. I am going to try that this weekend and see what happens. I am crossing my fingers.
