1 - 7 of 7 Posts
XTRMRSX said:
The UPS label on my box says 53lbs. So, minus all the hardware and other miscellaneous stuff that comes in the box, I would say the SC/manifold itself is around 40lbs.
Thanks for the info. Does the extra weight affects the car's handling?
Master of Auto Talk
... remember, you're taking OUT the stock intake mainfold. So it's more or less like your replacing the IM with a super duper intake mainfold. After all said and done, you probably gained an extra 20 some odd pounds. I was worried about the weight gain too before i got mine but then realized it was no bigggie. Actually, you'll want as much weight in the front with this supercharger as you can get when you launch, due to traction problems and hooking-up lol ;)
Master of Auto Talk
wdsonny said:
Put some midgets on the hood and some sandbags. You will hook up.
the midget idea wasn't that bad, but once you brought up sandbags
......then i knew you were joking :laughing:
1 - 7 of 7 Posts
