1 - 6 of 6 Posts
Eveything is fine, except the oil return line (from the turbo to the oil return pipe) is leaking. I dont understand. The bolts are tight, the only thing i can think is that maybe i got a bad gasket or somthing. I dont know. Any ideas or suggestions.
i was reading through this section of the forum and came across people with similar problems... i think it was covered in one of the stickies... might wanna take a look...
K series tuning liberator
my banjo bolt in the oil drain hole leaks a very little bit. It's on as tight as it will go.......but it is not a problem. Very little oil leaks...like a drop every two days.....so i am not worried about it.
pics?
Discussion Starter #5
Alright i ripped out the turbo and fixed the leak. there was somthing stuck on the gasket. no worries. thanks though
1 - 6 of 6 Posts
