1 - 20 of 47 Posts
i just sold the type-s and i think i want a tsx how do you like your rides? what are the good things about it and bad things? 6 speed or auto,would it really make a diff since its a luxury car? what about mods what is there available? mostly show or go?
well i would appreciate the input thanks :thumbsup:
Reactions: TypePR
I just traded in my '06 TSX pearl white w/ navi for an '06 RSX type S in blaze orange. Loved my tsx! It was quick and sexy. Had to get rid of it though because the payments were killing me! The navigation is sick and alot better than mercedes, audi, and lexus- no doubt about it. I think the tsx is more sport than luxury, but it is pretty luxurious with the navi- heated seats-everything power-bluetooth and all the good stuff. I've only had my rsx for a week now and even though it is bad ass, damn I MISS MY TSX!
i have an auto with intake and exhaust. i kind of regret not getting the 6 speed since i feel as if i want something quicker. its quick but by no means fast. theres a bunch of lip kits available, along with exhausts, intakes, etc. there are no turbo kits but there is a supercharger available.
overall i'm happy with my tsx besides it being alittle underpowered. its a great sporty luxury car for a great price
Obviously you haven gotten into a 06-07 Lexus especially the LS. Its ok to like your car but its not ok to downgrade on others to make ur car look better...
LEXUS LS460---Im only doin this because of BlazeOS comments
Engine & Performance
Engine Type 4.6-liter V8
Horsepower 380 @ 6,400 RPM [3]
Torque (lb-ft) 367 @ 4,100 RPM [3]
Displacement (L/cu in) 4.6/281
Valves 32
Cam Type Four-cam
Electronic Timing Dual Variable Valve Timing with intelligence (VVT-iE)
Compression Ratio 11.8:1
Emissions Ultra-Low Emission Vehicle (ULEV II)
Performance
0 - 60 mph (sec) 5.4 [3] [4]
Top Track Speed (mph) 130 (electronically limited) [3] [4]
¼-Mile Acceleration (sec) 13.9 [3] [4]
Aerodynamic Drag Coefficient 0.26
Fuel Economy
City (mpg) - estimated 19 [5]
Highway (mpg) - estimated 27 [5]
Fuel-Tank Capacity (gal / L) 22.2 / 84
Transmission & Drivetrain
Drive Type Rear-wheel drive
Electronic Traction Control Traction Control (TRAC)
Electronic Stability Control Vehicle Dynamics Integrated Management (VDIM) [6]
Final Drive Ratio 2.937:1
Transmission Eight-speed sequential-shift automatic
Electronic Transmission Electronically Controlled Transmission with intelligence (ECT-i)
Body & Chassis
Body Type Five-passenger luxury sedan
Doors Four
Construction Welded-steel unibody
Suspension
Suspension, Front Independent, upper and lower multi-link double joint suspension arms with coil-over monotube shock absorbers and stabilizer bar
Suspension, Rear Independent, multi-link double joint suspension arms with coil-over monotube shock absorbers and stabilizer bar
Steering
Steering Electronic Power Steering System (EPS)
Steering Turns (Lock-to-Lock) 3.2
Turning Circle (ft) 35.4
Brakes
Brakes Four-wheel power-assisted disc brakes
Anti-lock Braking Four-sensor, four-channel
Braking Assist Brake Assist [7]
Electronic Brakeforce Distribution (EBD) Electronic Brakeforce Distribution (EBD)
Discs, Front (in) 13.14-in ventilated, power assisted [8]
Discs, Rear (in) 12.4-in ventilated, power assisted [8]
Wheels & Tires
Rim Type Nine-spoke, 18-in aluminum alloy
Wheel Size (in) 18 x 7.5 [9] [10]
Tire 235/50R18 V-Rated all-season tires [9] [10]
Safety
Airbag
Driver Dual-stage front (SRS) [11]
Front seat-mounted side (SRS) [11]
Side curtain (SRS) [11]
Knee airbag (SRS) [11]
Front Passenger Dual-stage front twin-chamber (SRS) [11]
Rear Passenger Rear-seat side curtain (SRS) [11] Optional
Electronic Stability Control Vehicle Dynamics Integrated Management [6]
Electronic Controlled Braking (ECB)
Anti-lock Braking (ABS) Four-sensor, four-channel
Pre-Collision System (PCS) Radar [12] Optional
Electronic Tire Pressure Lexus five-sensor [13]
Frame Highly rigid body structure
Impact Resistance Side-impact door beams (front-gusseted)
Reinforced in pillars and doorsills
Impact-dissipating upper interior trim
Crumple Zones Front and rear
Steering Column Collapsible steering column
Seatbelts Three-point seatbelts for all seating positions
Pre-tensioners and force limiters for front and rear outboard seats
Height-adjustable front shoulder belt anchors
Locking Seatbelt Control Automatic Locking Retractor/Emergency Locking Retractor (ALR/ELR) seatbelts for all passenger seating positions. Driver's-seat Emergency Locking Retractor (ELR) only for driver's seat
Child Restraint Child Restraint Seat (CRS) tether anchor brackets for rear outboard seating positions
Child Safety Locks Manual for the rear passenger doors. Window-lock button on driver door control
Backup Camera Full-color display [14] Optional
Anti-Theft Protection Theft-deterrent and engine immobilizer, with in-key transponder
Emergency Trunk Release Emergency interior trunk release
Valet Lockout Trunk and glove box
Headlamps High-Intensity Discharge (HID) headlamps with dynamic auto leveling
Dual-swivel Adaptive Front Lighting System (AFS)
Headlamp Washers Headlamp washers Optional
Running Lights Daytime Running Lights (DRL)
Foglamps Integrated foglamps
Taillamps LED taillamps
Defroster Auto-off timer for rear window
Windshield Wipers Rain-sensing intermittent wipers with mist cycle
Mirrors Power-adjustable, auto-folding outside mirrors with defoggers, puddle lamps and auto tilt-down in reverse
Glass Water-repellent windshield and front-door glass with UV reduction
First Aid Kit Included
Tool Kit Included
Exterior Specs
Length (in / mm) 198.0 / 5,029
Width (in / mm) 73.8 / 1,874
Height (in / mm) 58.1 / 1,475
Wheelbase (in / mm) 116.9 / 2,969
Ground Clearance (in / mm) 6.1 / 156
Curb Weight (lb / kg) 4,244 / 1,925
Exterior Features
Automatic on/off projector-beam headlamps with auto-off delay
Exterior glass with UV reduction
Interior Specs
Seating Capacity Five
Headroom, Front (in / mm) 38.0 / 965
Headroom, Rear (in / mm) 38.0 / 966
Shoulder Room, Front (in / mm) 58.5 / 1,485
Shoulder Room, Rear (in / mm) 56.9 / 1,445
Trunk Capacity (cu ft/ L) 18.0 / 509
Interior Features
Trim Medium brown walnut, dark gray bird's-eye maple or dark brown ash burl interior wood trim
Leather-trimmed interior
Center Console Center console with sliding armrest and storage bin
Door Trim Leather
Seat Trim Leather
Steering-Wheel Trim Wood- and leather-trimmed
Wood- and leather-trimmed heated steering wheel
Shift Knob Trim Wood and leather
Power Seats 16-way driver's (including dual-function lumbar) and 12-way front passenger's (including lumbar) power seats
Climate-Comfort Seats, Front Climate-comfort seats with heat/cool knob
Climate-Comfort Seats, Rear Climate-comfort seats with heat/cool knob
Heated Seats, Rear Heated seats
Heated Steering Wheel Heated steering wheel
Headrests Height-adjustable headrests for all seats
Memory Systems Lexus Memory System to control power driver's seat (except lumbar), outside mirrors, driver's shoulder belt anchor height and steering wheel
Lexus Personalized Settings (LPS) [15] to personalize electronic functions
Electronic Releases Illuminated interior trunk-lid and fuel-filler door releases
Floor Mats Carpeted floor mats
Vanity Mirrors Lighted front and rear vanity mirrors
Sunshade Rear power sunshade Optional
Parking Brake Electronic parking brake
Storage Pockets Foldable front-door storage pockets
Comfort & Convenience
Cruise Control Cruise Control
Dynamic Radar Cruise Control [16]
Climate Control Dual-zone automatic climate control and automatic recirculation mode
Air Filtration Interior air filter with smog sensor
Navigation System Lexus voice-activated HDD Navigation System [17] with backup camera [14], Bluetooth® technology [18] , XM® NavTraffic™ [19]
Remote Keyless Entry SmartAccess [20]
Remote Keyless Ignition SmartAccess [20]
Remote Windows Remote-linked windows and moonroof opening
Moonroof Power tilt-and-slide remote-linked moonroof with one-touch open/close and sliding sunshade
Retained accessory power for moonroof and windows
HomeLink® Transceiver Operates compatible garage, gate, home lighting and home security systems
Power Windows Power windows with one-touch auto open/close
Power Door Locks Auto lock/unlock, anti-lockout feature and driver's two-turn unlock feature
Power Trunk Closure Power trunk closure
Power Mirrors Electrochromic auto-dimming inside rearview mirror and outside mirrors
Power Seat, Driver 16-way controls (including dual-function lumbar)
Power Seat, Passenger 12-way controls (including lumbar)
Feature Memory System Lexus Memory System to control power driver's seat (except lumbar), outside mirrors, driver's shoulder belt anchor height and steering wheel
Adjustable Steering Wheel Power tilt-and-telescopic steering column with automatic tilt-away
Electronic Park Assist Intuitive Parking Assist
Parking Guidance Advanced Parking Guidance System [21]
Steering Wheel Controls Audio and display controls, brake hold and display controls
Retained Accessory Power Retained accessory power for windows, moonroof and audio system
Instrumentation Electroluminescent instrumentation
Illuminated Entry Illuminated entry system
Outside Temperature Gauge External temperature display
Fuel Consumption Gauge Fuel consumption display
Cupholders Dual cupholders, front and rear
Audio & Entertainment
Audio System Premium Sound System with Digital Sound Processor, Automatic Sound Levelizer (ASL) and in-dash, single-feed, six-disc CD auto-changer
Speakers Ten
Auxiliary Port Auxiliary iPod®/MP3/Windows Media® Audio (WMA) port
Audio System Mark Levinson® [22] Reference Surround Sound Audio System, Hard Disc Drive (HDD) stores up to 2,000 songs, 7.1 architecture and in-dash, single-feed, six-disc DVD/CD auto-changer featuring DVD-audio and DVD-video playback.
Speakers 19
Watts 450-watt @ 0.1% THD; 20-20,000 Hz [23]
Satellite Radio XM Satellite Radio [24] and real-time traffic capability
Antenna In-glass antenna with FM-diversity system
Shark-fin antenna
CLUBRSX.com Supporter
He simply stated the navi is better on the acura's than the competiton...This is a true statement and he by no means downgraded other brands.
Well this is exactly wat he said
"The navigation is sick and alot better than mercedes, audi, and lexus- no doubt about it."
^^^The navi not the entire car. You copy and paste every single item for the LS460 like he's comparing all that crap.
02' WS6 T/A FTW!
I actually agree with this comment 100%. My Dad just traded in his 04 MDX, and got a 06 Porsche Cayenne-S....and the the only thing he doesnt like is that the navi in the MDX was sooo much better/easier to control while driving than the Cayenne.
Not sure about Mercedes though, only car I havent driven out of those listed w/navi.
i has vtak!
my dad had a 6-speed type s. its definately more luxurious than my type s, but it was a lot slower although the torque on the TSX is noticeably higher on the butt dyno. lol.
The only problem that we had was after about 30k miles his clutch pedal started to squeak really badly and his clutch would chatter, so u may want an auto.
Hurm
:iamwiths:
he's right acura navi is one of the best and easiest to use...hes not trying to say the car is better...:vtec:
I got a TSX loaner w/navi once and I must say it is really sweet. I never used any other brand navi tho (c'mon, I'm poor) but the TSX navi is sweet.... I'd love to get into a TSX but I just can't imagine parting w/my type S and downgrading in terms of power :(
If the TSX was faster than it is, my RSX would already be gone.
EDIT: Then again, I haven't driven a 6spd TSX... is there a HUGE difference between the auto and 6-spd?
The 6spd is substantially quicker but the auto is fine. Every time I drive my wifes 07 tsx I sit and wonder...how the hell can a 4banger pull this heavy car so easily. People always say the tsx is so slow, but when driving around town at part throttle with the a/c on and passengers it has great get up and go, way better than my rsx did when it was stock. The car pulls hard when it's in vtec, but the problem is that it falls way out of vtec when the auto shifts, I'm not sure if the 6spd does this.
how does the 6spd TL type-S compare to a rsx-s?
1 - 20 of 47 Posts
