1 - 13 of 13 Posts
Royale with cheese.
Alright, i just bough a comptech race header, the header adapter, es MMs, Injen CAI, and nology hotwires. my questions are, with the comptech header are there any exhausts that do not require the adapter? also, i have the powergetter, will i be restricting any power with this exhaust, and should i up for the comptech exhaust because it will give me more power or is it such a neglible amount it isnt even worth it? thanks
Royale with cheese.
Discussion Starter · #2 ·
also is there any chance i can hit 200whp?
for me to poop on!
the only exhaust that doesn't require the adapter is the Comptech race exhaust, and no your PG should be just fine.
good choices enjoy
Back in Black
More and more, it seems to me, that go Comptech or you go the fulll legal route. Both produce power, MMmotornutz produced another 10 lbs of torque and another 10 horses with a cat back, shorty headers, and a high flow cat. Why go with the J RH for just a few more horses?
I don't know... The Comptech is producing unbelievable gains. There's 3 items that produce a shit load of power on this car. CAI+Hondata. Comptech header. Cams. I think that's all you need for low 13s. I can't wait to get my Comptech.
Yeah, you should be somewhere around 200 horses. Add Hondata too!
Be aware that if you run Hondata#4 with your Comptech race header, you will have a pretty good chance of running very and dangerously lean :nervous: . The comptech race header improves flow so much that it leans the car a little bit already, add Hondata's air:fuel leaning after the 5200 rpm to get rid of the stock VTEC dip, and you got one lean running engine that might run out of breath :nervous: . I advice that you get an SAFC or VAFC and get it dyno tuned asap, cause I dont think you dont want your car to go BOOOOOM!!!
edit: Hondata just informed that they dont lean out this area, its all due to the header :eek: . I need to see a Hondata#4 air:fuel reading with an intake only :D .
Back in Black
Exactly! Also, dynos and power graphs are all over the place with this header, presumably because the Hondata flash doesn't have a 'tune' for it.
Everyone with outstanding gains using this header has the K20 flash and DC5R cams. I don't think anyone really knows this...
would that be the same case for a base engine?
1 - 13 of 13 Posts
