1 - 7 of 7 Posts
Don't :firemad: me if this has already been settled, but will a car (hypothetically speaking ;) ) pass inspection if the second O2 sensor is turned off with the new ECU?
It has not been tested. There is a possibility it will, but you have to remember that the ECU is for off-road use only. :)
Discussion Starter · #2 ·
Can no one answer this? Doug? Anyone?
38 views and no one knows?
Censored said:
It won't pass an emissions test but I guess it could pass the visual inspection.
Well the reason I ask is we don't have a "sniffer" test on OBDII equipped vehicles. Here it is plug it up, check the emissions levels, check the gas tank pressure and youre done.
K20A2 said:
If that is the test it could pass but no one here is going to promise it.
Oh, I understand that. I just wondered if those type tests look for the OBDII function to be in place or if it is just a check for any codes present within a given period of time.
1 - 7 of 7 Posts
