1 - 20 of 26 Posts
TENEBRAS
Thought this would be helpful to other CRSX members!:D
Sensor Location and part#s for K20/24. This is very useful information it helped me.
Pictures in order below
X: A/C compressor
Y: Water Pump
Z: Auto Tensioner Pulley
1: Auto Tensioner
2: A/C compressor harness
3: Passenger side engine mounting bracketX:
4: Charge harness
5: Intake manifold
6: Thermostat housing
7: Engine harness to Charge harness connectors
8: Engine harness to Charge harness connectors
9: Battery ground
10: Clutch Slave Cylinder
11: Starter bendix
12: Starter
13: Power Harness for Alternator
14: ******* bolt hole
15: Knock Sensor (it is just behind the manifold support on the block)
16: IAC (idle air controller)
17: TB heater line
18: TPS
19: engine harness
20: Brake Booster Vacuum line
21: engine harness
22: IAT, wire and connector
23: Shifter assembly
24: Shifter Cables connection
25: Front transmission mount bolt (not used in swap)
26: Front transmission mount bolt (not used in swap)
27: Front transmission mount bolt (not used in swap)
28: EVAP solenoid
29: EVAP Test Port
30: Valve Cover breather heating assembly
31: Throttle body (opening for air intake)
32: Coolant line (feed/return?)
33: Bolt
34: Driver's-side transmission mount bolt
35: Transmission Vent
36: Reverse switch
37: Coolant Outlet
38: AAV & line (Air Assist Valve)
39: Fuel line
40: Fuel Pulse Damper
41: Fuel rail
42: Fuel injector wiring loom
43: Injector #1
44: Injector #2
45: Injector #3
46: Injector #4
47: Engine oil filler cap
48: Engine oil dipstick
A: Coolant outlet /inlet to heater
B: Vehicle Speed Sensor, or VSS
C: Clutch line
D: Tranny ground
E: Main engine harness
F: Oil Filter
G: Coolant drain bolt
H: Oil pressure sender
I: Crank Position Sensor
J: Part of Oil Cooler
K: Another part of Oil Cooler
L: Crank pulley
M: Vtec Solenoid
N: VTEC oil pressure sensor
O: brake booster line
P: Evap control valve hardline.
Q: VTC oil control solenoid valve
R: Vin plate
S: Exhaust manifold heat shield
T: Header
U: Charge harness
V: Tranny bracket
L: Crank pulley
M: VTEC Solenoid
W: Alternator
X: A/C compressor
Y: Water Pump
1: Auto Tensioner
Another close up:
M: Vtec solenoid
TENEBRAS
Sensors/Valve Assemblys:
-Knock Sensor
Accord 04-07 Knock Sensor P/N: - 30530-PPL-A01
Civic 03-05 Knock Sensor P/N: - 30530-PPL-A01
CRV 03-07 Knock Sensor P/N: - 30530-PPL-A01
Element 03-07 Knock Sensor P/n: - 30530-PPL-A01
TSX 04-07 Knock Sensor P/N: - 30530-PPL-A01
RSX 02-06 Knock Sensor P/N: - 30530-PPL-A01
RSX-S 02-06 Knock Sensor P/N: - 30530-PRB-A01
Civic Si 06-07 Knock Sensor P/N: - 30530-PRC-003
-Crank Position Sensor
Accord 03-07 Crank Position Sensor P/N: - 37500-RAA-A01
Element 03-07 Crank Position Sensor P/N: - 37500-RAA-A01
TSX 04-07 Crank Position Sensor P/N: - 37500-RAA-A01
CRV 02-07 Crank Position Sensor P/N: - 37500-PNB-003
Civic 03-07 Crank Position Sensor P/N: - 37500-PNB-003
RSX-S 02-06 Crank Position Sensor P/N: - 37500-PNB-003
RSX 02-06 Crank Position Sensor P/N: - 37500-PNB-003
Civic Si 06-07 Crank Position Sensor P/N: - 37500-PNB-003
-Camshaft TDC sensor
Civic 02-07 Camshaft TDC Sensor P/N: - 37510-PNB-003
RSX 02-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
RSX-S 02-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
CRV 03-06 Camshaft TDC Sensor P/N: - 37510-PNB-003
CRV 07 ONLY Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
Accord 03-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
Element 03-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
TSX 04-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
Civic Si 06-07 Camshaft TDC Sensor P/N: - 37510-PNB-003 <-Exhaust- // 37510-RAA-A01 <-Intake-
-MAP Sensor
Accord 03-04 MAP Sensor P/N: - 37830-PGK-A01
CRV 02-04 MAP Sensor P/N: - 37830-PGK-A01
Civic 01-05 MAP Sensor P/N: - 37830-PGK-A01
RSX 02-04 MAP Sensor P/N: - 37830-PGK-A01
RSX-S 02-04 MAP Sensor P/N: - 37830-PGK-A01
TSX 04-07 MAP Sensor P/N: - 37830-PGK-A01
Civic Si 06-07 MAP Sensor P/N: - 37830-PNC-003
-Water Temp. Sensor
Accord 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
CRV 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
Civic 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
Element 03-07 Water Temp. Sensor P/N: - 37870-PNA-003
RSX 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
RSX-S 02-06 Water Temp. Sensor P/N: - 37870-PNA-003
TSX 04-07 Water Temp. Sensor P/N: - 37870-PNA-003
Civic Si 06-07 Water Temp. Sensor P/N: - 37870-PNA-003
-VTC Spool valve assembly
Accord 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
CRV 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
Civic 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
Element 03-05 VTC Spool Assembly P/N: - 15810-RAA-A01
RSX 02-06 VTC Spool Assembly P/N: - 15810-RAA-A01
RSX-S 02-06 VTC Spool Assembly P/N: - 15810-PRB-A01
TSX 04-05 VTC Spool Assembly P/N: - 15810-PRB-A01
Civic Si 06-07 VTC Spool Assembly P/N: - 15810-PRB-A03
-VTC Oil Control Valve Assembly
Accord 03-07 VTC Oil Control Assembly P/N: - 15830-RAA-A01
Element 03-07 VTC Oil Control Assembly P/N: - 15830-RAA-A01
CRV 03-05 VTC Oil Control Assembly P/N: - 15830-PNC-003
Civic 03-05 VTC Oil Control Assembly P/N: - 15830-PNC-003
RSX-S 02-04 VTC Oil Control Assembly P/N: - 15830-PNC-003
RSX 02-04 VTC Oil Control Assembly P/N: - 15830-PNC-003
TSX 04-07 VTC Oil Control Assembly P/N: - 15830-RBB-003 (same as 05-06 RSX-S)
Civic Si 06-07 VTC Oil Control Assembly P/N: - 15830-RBB-003
-Timing Chain Tensioner
02-07 CRV - 14510-PNA-003 (K24A1 and K24Z1)
03-05 Civic Si - 14510-PNA-003 (K20A3)
03-07 Accord - 14510-PNA-003 (K24A4 and K24A8)
02-06 RSX Base - 14510-PNA-003 (K20A3)
03-07 Element - 14510-RAA-A01 (K24A4)
02-06 RSX-S - 14510-PRB-A01 (K20A2 and K20Z1)
04-07 TSX - 14510-PRB-A01 (K24A2)
06-07 Civic Si - 14510-PRB-A01 (K20Z3)
07 Acura RDX - 14510-RWC-A01 (K23A1, Turbo) more Location PICS
1 - 20 of 26 Posts
