1 - 9 of 9 Posts
Trying to get more out of my 2007 crv. But you guys know the RSX heads. Cam you tell me if the K20A2 will fit my 2007 k24 in the CR-V? THANKS!!
Not sure, but I can tell you that its not worth it. You’d be rebuilding the bottom end, and would need an engine management system. I don’t think one even exists for your car.
it will work and fit. you need obvisouly some type of ecu to manage the calibration/tune
use the crv psngr bracket.
it goes together fine. I did one. reused oem headstuds works fine. even swapped out pistons for 09+ tsx pistons 11.1CR
1 - 9 of 9 Posts
