1 - 1 of 1 Posts
Hello all,
Like the thread states, what is all needed for this swap? I have an '03 base and would like to bolt in the 6 speed from the DC5-R (Y2M3) '02-04 model. I've heard the axles are 36mm on the 'R and 32mm on the Base. Is this the measurement taken at the out board joint's? If so are the inboard joints all the same size, spline count, and diameter for base, Type S, Type R? I'm wondering if the base axles will match the differential side of the 'R transmission? Also will the Base clutch assembly and flywheel work with the 'R 6 speed trans? I would like to keep the Base clutch because I just recently replaced it lol..
1 - 1 of 1 Posts
