1 - 6 of 6 Posts
03 rsx base
So I'm a noob to these k series engine building:shakehead I know I should have just got a type s but their really beat up down here in Phoenix anyways I want to see what I can do with a k20a3 first then I'm going to build a k20z1 or a2:fistbump:........ Anyway I want to up my compression on the k20 a3 can I just buy rod and piston and straight install them and just balance or would I need more work? I know there already thread out their but i look over and over and it doesn't really help me so anyone?
Vaginal Lubrication Tech
you could slap an A2 crank, pistons, and rods into your A3 block. then get an A2 head and KPro later on.
if your gonna go with a3 parts you probably wanna get 20 over pistons and rings, have the block bored but you may be able to get buy with having the cylinders honed and using stock sized pistons and rings. take it to a good machine shop and have them check it to see which one.
1 - 6 of 6 Posts
