I am currently doing a motor swap for someone and I am running in to wiring issues. I have a complete 05 RSX Type S with everything from wire harness to dash harness at my disposal. I removed the dash board already and the wires are different but can be mated with his old harness to make it work. My issue right now is if I can re-use the stock 05 ECU or do I have to use the 05 K-Pro route.
I am in the process of removing the dash and look at everything first hand to see what I am going to be really be dealing with.
Any feedbacks will be appericated.
I'll take pics when i remove the dash board and check out the dash wiring harness.
