Hey guys I have a auto rsx can I be able to swap for a k24 with a tsx auto ecu or its not posible
wat about the ecu?You can do it. TSX come auto. all you need to do is swap out long blocks, retain the wiring and drive it like normal, I have personally installed a few K24a2 motors in Auto Base RSX's
no it will not. tsx ecu will not be able to work with the rsx's multiplexor controls.Yeauuup you can use everything from your car just swap the long block out and have fun. It is really as easy as that.
are you sayin that u keep the rsx ecu with the tsx tranny? explain please.Yeauuup you can use everything from your car just swap the long block out and have fun. It is really as easy as that.
you cant have an auto kpro ecu. auto ecu DO NOT accept kpro, but the 02-04 can be flashed, not the 05-06 tho. djcarbine is runnin two ecu's. the auto for the tranny and the kpro for the engine.with an auto kpro ecu, yes you can do a k24 swap. ask djcarbine about this ecu as i have no clue on how you can go about getting this product.
because how many people do? you always see the classic cars w/ auto trannies and swapped motors. rarely a tunerjsut get a tsx... why bother w/ k24 auto in the rsx
