1 - 20 of 40 Posts
Hello, I have done some searching and came up with vague results. I have a k24a2 swap and am running the ep3 type r front sway bar. It is barely touching the sway bar. I am wondering with the little clearance I have will I be able to fit a buddy club race header. If not the BC then which one. Thank you in advance for the help.
i was wondering this same thing.. i have a buddy giving me a DC header and i have a megan header myself.. i dont want to use either of them.... hytech is so damn expensive but im gonna see what pricing they give me...
Super Moderator
I had my PLM header reworked to compensate for deck height as well as swaybar clearance. There was about 0.8-1" of material added to each primary.
1 of 1
ITR coil cover. :jelly:
DC5
only issue was that I had to weld a two bolt flange to the exhaust so it can bolt up to the two bolt flange the rh originally comes with. I don't mind since I have a custom 3 inch.
Resident hater
I'm running an ASP originally made for my k20. Fitment is tight, had to remove a couple heat shields and the sway, but it fits.
1 - 20 of 40 Posts
