1 - 12 of 12 Posts
While putting a K24 into a 02 rsx, can I use the stock header?
It's a 5 speed if that matters and the car is lowered roughly 2 inches.
Thanks.
regrets selling the rsx
yes and no. some people have gotten away with using the stock k20 header on a k24 block/head combo, but it's going to sit closer to the front sway bar and possibly angle the hell out of mid-pipe. after market header on a k24 in a rsx will be hit or miss; just depends on how the header is built. in short, you might be able to get away with it, but i wouldn't call it a good permanent solution.
New Old BB6
^ correct , any k24 owners/builders that wana chime in on what aftermarket header your running and how well it fits.
My Comptech Race Header fits fine. Don't bang against underbody or anything.
Only problem, no front sway bar.
I might put the 15.9mm EM2 front sway bar in. We'll see if it clears.
I know for a fact the 27mm progress front sway won't clear, unsure about OEM.
I really appreciate it guys.
We're doing the swap for a guy on a VERY tight budget. I'd also like to use all OEM parts.
Internet Crack Dealer
I just finished an K20/K24 install today and I had to stretch the TODA header by about an 1/2 and also do a pie cut in that piece. I think you will find that it won't work without some customization.
PORN STAR
I'm just wondering if either the Megan, OBX or Strup headers will work with a K24 and stock sway bar... My RSX is on a very limited budget.
1 - 12 of 12 Posts
