hidden s/c :shady:
AFAIK it is the VTC that makes the slight whine.dont the k-series engines whine normally?
I am praying for your motor.You were supposed to use the k20 chain mani had the same problem with my k24 swap. i could hear and feal it in the oil pan.then after about 4000 miles it whent away.the only thing i think it could have been is i used the k20 oil pump but the k24 tentioner and triangel shaped giude that bolt to the block and it was a little longer than the k20 giude. i think over time the giude wore down becuase it is plastic and the noise went away. i justray: pray every day i dont have little pieces of plastic eating away at my rod and mian bearings. i now have 7000 miles on it and have raced and run the the shit out of it and had it tuned by jeff evans and he ran the shit out it so i think every thing is:thumbsup:
i did not say i used the k24 chain just the k24 giuds. i think it would be imposible to use k24 chain with k20 oil pump even though it is only one link shorter it will never fit.I am praying for your motor.You were supposed to use the k20 chain man
I'm getting used to it..Just turn up the music or roll down the windows and listen to the engine/exhaust.i have a wining sound too. its pissing me off
