1 - 6 of 6 Posts
OK so heres the scoop ima be switchin the bottom block of my k20z1 motor to a
k24 one. still keepin cams the same oil pan an will be using the stock k20 heads. I guess this motor swap is called the frankenstien swap. NOw wit that being said do i need kpro for this swap to work?
:vtec::vtec::vtec:
G
:vtec::vtec::vtec:
Yes.
Average Member
the car will run without k-pro, but k-pro is necessary to have it run properly. I would try and avoid driving it without it.
Def get the Kpro you will need to get it tuned to run properly.
1 - 6 of 6 Posts
