1 - 3 of 3 Posts
Hello everyone, greetings from Panama friends ... I am building my project of the DC5 base 2002 K24A2 Turbo sidewnder Automatic. The ECU does not worry me much since I will adjust with Ktuner for 05-06 + the Harness for 02-04 ... I have the opportunity to get a TSX transmission, the question is: Can it be connected to the RSX chassis? The base of the transmission side will be customized. The question is: Can I use the OEM OEM to start the car? or I should use the Ecu of TSX, and the other thing is that if there is something else electrically speaking I should do (some sensor or something like that) that I must modify or add to the RSX wiring. The car will not be manual transmission for now as the idea of ​​the project is to assemble the car for daily use with A/C and P/S .... I hope you can help and give positive feedback on my project. Thanks and greetings to all
I know for sure that the TSX ECU won’t work, Ktuner or Kpro are the way to go. By my understanding, the TSX trans won’t bolt into our chassis without fabrication. I’ve also read posts that say all k series transmissions will fit. You’ll need to do more research on that to know for sure.
1 - 3 of 3 Posts
