1 - 11 of 11 Posts
I Hate Honda's
Is there anyone on here running the KTuned Billet Race Spec shifter setup? My Type R center console kinda restricts it from going into reverse, and the OEM 05-06 center console doesn’t let it go into reverse at all.
Any tips? I’ve been rolling without a center console at the moment.
I Hate Honda's
I thought you had to ditch the boot plastics to run that shifter?
Not positive. I may try to trim that middle removable piece so I can keep that little cubby hole below the ebrake handle and go from there.
I Hate Honda's
You have to ditch the center console and boot to run that setup. Or remove the shift boot ad modify the console.
Yeah I know that much. The boot has already been ditched. I was hoping someone had a suggestion on how much you had to trim, and/or pics of their setup. The shifter is already in, but I haven’t modified either of my center consoles yet.
i have it, what i did is get an Auto shifter plastic surrounding and cut a small section where the reverse or 6th hit the plastic, of course with that shifter you can't use the boot anymore. That works for the OEM center console only.
I ended up cutting mine for my hybrid shifter, so I could have it closer to me. Hacksaw and sandpaper lol then put an led strip surrounding shifter
Yeah, but I mean he said it hits the console, I was just giving an idea of what I did since the hybrid was hitting where I wanted it set up as well.
1 - 11 of 11 Posts
