1 - 7 of 7 Posts
Hello all,
I currently have an 06 Type S with a reflashed ECU from Ktuner. My concern is that it may cause problems with the smog check as they do the OBDII monitors test. As stated by members of the forum, the reflash disables the secondary O2 sensor and it may cause issues with the readiness monitors. They said that it disables the readiness monitors as a whole and it also shows the O2 monitor as “N/A” for them.
So my question is, should I go forward with the reflashed ECU since my CEL won’t be there or should I be concerned that my readiness monitors will be incomplete, causing me to fail the smog check?
Thank you in advance!
Bro, I have an even better idea. Because you don’t believe me, go to your local auto parts store and have them check. It’s free, and will save you the hassle of having to get a smog test done twice.
My bad bro, I do believe you. I just thought it would be a different situation considering you have the End-User and I simply have the reflash with my stock ECU. I will definitely head to an auto parts store soon!
1 - 7 of 7 Posts
